Ricoh MP C 4502 Streaks
  • deadeyefive
    • Dec 2019
    • 2
    Having problem with ricoh mpc 4502 leaving lighter streaks when printing. Does not appear to be a roller issue and only when printing color photos. Drum and developer has been cleaned and appears to be in good shape. Help!!
  • FrohnB
    • Jul 2017
    • 1919
    Re: Ricoh MP C 4502 Streaks
    Have you cleaned the laser glasses for each color?
    What's the total count for development units?
    Did you actually split drum and dev. unit in two to check that the doctor blade gap isn't obstructed in developer units?
    Omertà
    • deadeyefive
      • Dec 2019
      • 2
      I didn't take it apart. didn't want to pry it open. Is there a trick to separating it?? I did blow it all out though. there was a lot of toner that blew out.
      • FrohnB
        • Jul 2017
        • 1919
        You may have made things worse by "blowing them out", and of course there was toner that blew out! You blew air into the developer/ toner mixture contained in the unit!!
        You can easily split the units by taking out 4 screws and 1 e-clip and a bushing, but this begs the question, Are you at all confident in your abilities to disassemble and then reassemble these units? With your "blow job" solution, I have a feeling you might not be a tech.
        Omertà
          • 37489
          Y ou do not need to take it apart to clean the shield glasses. There should be a tool for cleaning it mounted on the inside of the door.
            +3 FrohnB
            clearly he is an end user...
            he didn't even respond to the "clean the laser glass"
            i HOPE he pulled the drum ALL the way out before he 'blew it all out'!
            clearly a rookie move.
              • 37489
              Yoi got lucky in that a couple of top Ricoh techs on this site are some of the few who regularly check here for posts. In the future you will get more help if you post to the actual Ricoh tech forum.
              https://www.copytechnet.com/forums/r...tetner-lanier/
                • 37489
                +3 FrohnB
                I wonder if the "five" in his handle is his IQ?
                • takefive
                  • Apr 2021
                  • 2
                    • 37489
                    Over a year late with nothing valid to contribute. Go away grave robber.
                    • takefive
                      • Apr 2021
                      • 2
                      try replacing the black developer unit, looks lake a bad mag roller bitlife pcjiofi.local.html
                      • sungurvid
                        • Mar 2022
                        • 2
                        i think this issue is already resolved.
                        • sungurvid
                          • Mar 2022
                          • 2
                          vidmate app download insta save
                          but i think There should be a tool for cleaning it mounted on the inside of the door.
