Error @remote In. Req. No.
  • VasileiosG
    • Feb 2017
    • 14
    Hello,
    Im having the following error on some machines im trying to put them to @remote.
    We are always taking about embeded rc gate.
    Even if i do 5816-209 im having an issue which says:
    Invalid req. No and says about wrong parameters.
    Any solution?It should be something obvious but i cant seem to find it.
  • aktasson
    • Feb 2017
    • 201
    Re: Error @remote In. Req. No.
    I think you have to init and rewrite the cert of the machine. If 802.x is enabled, after that you have to write customers cert for network auth.
    • VasileiosG
      • Feb 2017
      • 14
      Should i do then,5870-003 and then 001?
      • TonerMunkeh
        Professional Moron
        • 3865
        Depends on the machine. If it's an 04 or newer, it's the 2048 bit certificate. If it's an 03 or older, it's the 512 bit. If you need to clear out the @remote totally, run both of those and 58160-209. If it still errors with wrong parameter, the request number is invalid.
        Hit it.
        • zed255
          How'd ya manage that?
          • 1024
          @Remote is giving you a result back indicating that your request # might have either had an error in it when you were given it or the number was too old. The Centre Server only accepts request numbers that are less then 45 days old (or some such thing, I generally consider a number stale if it is more than a month old). I would request a new number to try first. I suggest:
          1) Update your machine's firmware, restart
          2) Clear @Remote using SP5-816-209, restart
          3) Write a fresh common certificate with SP5-870-3 to initialize and either SP5-870-4 for a 2048bit certificate (preferred for future compatibility and automatic firmware if available) or SP5-870-1 for a 512bit certificate, restart.
          4) Verify in User Tools that @Remote services are allowed and not off or limited.
          5) Generate / request a new request number.
          6) Verify with client IT that traffic on ports 443 (TCP and UDP) can reach the @Remote servers in Japan. I have seen network traffic filtering by many different criteria, including geographical.
          7) Reattempt activation and if it fails, re-clear the system adding step 2-1/2 to run SP5-801-3 (SCS) and SP5-801-11 (NCS), restart and try again. Print off / record all network setting before running the SCS and NCS clears as you will have to re-input the settings.
          • FrohnB
            • Jul 2017
            • 1919
            Yes you should.
            We do 5-816-209 Install Clear.
            Then 5-870-003 Initialize.
            Then 5-870-001 Writing.
            Did you make sure it is removed from the Center GUI?
            Make sure Fax line is unplugged, have had a couple that try to receive fax when registering and it gives me an error result of "4".
            Make sure no one is trying to send a print job either, although I don't think this really affects it when you're in service mode, but just to be sure.
            Omertà
              • 37529
              Either my dispatcher or I would request the number either the day of or the day before going out on the call to set it up.
              • zed255
                • 1024
                I have CS access and generate the request numbers for myself and others on my team, so in my case I can deal with new request numbers on the fly. I realize for most the number has to be requested in advance.
                We get requests to connect @Remote and those requests usually go through our @Remote team and as such usually have a new request number attached to the call.
                I suspect if he was given the number then either some digits were not recorded properly or it is a 'stale' request number.
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  Verify as to whether the site uses a proxy server.
                  I've seen that give a parameter error many times.
                  • VasileiosG
                    • Feb 2017
                    • 14
                    Thanks a lot for your answers,sadly we import the machines and we do not know the previous state of the @remote.And know that i know the whole procedure i'll try it next time.Again thanks a lot
                    • VasileiosG
                      • Feb 2017
                      • 14
                      New issue,guys.On some machines,without firewall,without any issue on the network,and without pre-programmed rc gates it takes far too long to connect to ricoh's server and i left it over 15 minutes trying.No error,no nothing.If i reload the wim i get a 503.
                      Any thought?
                      • aktasson
                        • Feb 2017
                        • 201
                        Any thought?
                        Customer is using a proxy?
                        Check --> sp5816-201 (if 0=OK)
                        -204 (9=trying to request, 0=OK)
                        -207 (9=trying to request, 0=OK)
                        • VasileiosG
                          • Feb 2017
                          • 14
                          Customer is not using proxy,
                          I can't do the sp's as i am from remote and my customer is less than ideal to mess with the sp's.Any other solution?
                          • aktasson
                            • Feb 2017
                            • 201
                            Something wrong with the @remote request no? I asume it's a cumin installation?
                            This works only on site to the machine:
                            With sp5816-201 check the state
                            -202 entering request no.
                            -203 start requesting
                            -204 Waiting to change from 9 to 0
                            It's generally possible to start a @remote service poling by the panel to the center server. Was already done?
                            • keithxxiii
                              Just a tech
                              • Nov 2014
                              • 469
                              have you tried to ping the @remote servers in japan before connecting?
                              I noticed that some of the machines that faces issues while connecting when a google dns was added, it starts working fine.
                              I am trying to figure out how is it related to google dns if the customer has their own dns.
                              Aye! Cut the crap
