Ricoh Aficio mp c2050
  • cliffhangers
    • Feb 2010
    • 243
    I have change the board of ricoh mp c2050 when I put it on it cames on and stand at the same position for long and latter fit error code SC 672 or 670.what can I do to solved this problem thanks in advance.
    • 37556
    Re: Ricoh Aficio mp c2050
    For a "senior tech" you sure don't appear to be able to fix anything.
    • davel
      • Oct 2011
      • 1107
      Which f###ing board.
      • fshead
        • 2376
        maybe 1st>>
        what board and why was it changed?
        are you a tech or a cheap customer trying to beat paying for labor..
        Your posts makes you look like a end user..
          why the hell didn't he give us the 'board' info in his OTHER post on the same subject?
          he must wanna earn red flags!
            1) why the fuck did you start two threads..same machine ..same topic... little info in each
            2) DO NOT START MULTIPLE THREADS ON SAME SUBJECT
            3) clearly you aren't a trained.. hire one.
            • Klydon
              • Mar 2009
              • 243
              For purposes of conversation on these, my guess is perhaps a HDD issue. I have had 2050's give me long start ups, long waits, SC 672 and have it be a HDD. I have heard it could be memory, but have never had that happen first hand. The key with this particular series is to simplify as much as possible (IE, disconnect HDD, fax, etc) and see if you can get it to come up. The processor is weak on this machine and likes to code if the wind is blowing the wrong way or if it is a even day on a odd week with a full moon.
