ricoh 2501 fusing
  • Gab
    • Aug 2015
    • 671
    ricoh 2501 fusing
    Does anybody knows if fusing unit of 2501 is the same with that in 2000?
    Re: ricoh 2501 fusing
    doubtful
    have you checked PM's for both?
    Speed diff is a major factor
      • 37534
      Very similar but according to the Product Support Guide, all the PM parts are unique to the 2501.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        No not the same the mp2501 is the same as MP2001 the MP2000 is closer to the old af2018
        Regards Mark
        • Gab
          • Aug 2015
          • 671
          believe it or not , it works. I just replaced thermistors .
          • StephenB
            • Aug 2015
            • 244
            I went thru this a while ago. It will work, but the 2501 pressure roller has a larger diameter. Similar to a 2500.
            It would cause a build up on the upper heat roller. I replaced that upper 2-3 times before I just used all OEM rollers made for the 2501. That solved my problem.
