LW324 Images shifting
  • jonm
    • Jun 2019
    • 7
    I have a customer who uses a LW324 to print Blue Prints. The first page seems to print fine but after the first page the images shift significantly, more and more with each additional page. This is causing sections of the blueprints to not even print on the page at all since the image has shifted so far over. We have tried adjusting the size of the prints but cannot change much as this would change the scale of the blueprints. Has anyone else encountered this issue or have any ideas on how to fix it? Thank you in advance.
  • adween shaari
    Senior IT Technician
    • May 2012
    • 47
    Re: LW324 Images shifting
    Have sample print?
    Sent from my INE-LX2r using Tapatalk
      • 37474
      Normally a problem with either software or driver, especially when using pre-cut sheets. Line feeds are being sent at the end of a page instead of a form feed. If the number of line feeds is more than needed to reach the end of the sheet, the extra feeds are inserted in front of the next page's data.
