Ricoh C901s
  • afterhours
    • Mar 2017
    • 152
    Ricoh C901s
    Hello,
    Can someone please help.
    I have a custoer with a Ricoh C901s giving the code sc367.
    The Service manual give this cause...
    An abnormal condition is detected when output of one of the TD sensors fails to
    fall within the range of 0.5V to 4.5V.
    I followed the instructions in the service manual and ran a...
    SP3820
    Then Checked with...
    SP3821
    The result was 99999999, the doors were closed
    The machine said that the sp was complete although it kept running and saying something like self checking in the bottom left corner of the display.
    Can someone pleas help me see what im missing or if there is a common cause to this?
    Thank you in advanced!
    Im a Loser Baby!!!
    • 37739
    Re: Ricoh C901s
    Did you lookup in the service manual what 99 failure code indicates? Assuming you did not, it means Forced Termination. Something occurred that prevented Process Control to complete running. Door open, power off, or other problem interfering with process control self-check.
    You could have a flaky door switch. A high SP7504-001 jam count would confirm this.
    • afterhours
      • Mar 2017
      • 152
      Re: Ricoh C901s
      Jam count is very low on this machine.
      Im a Loser Baby!!!
      • butcher
        • 48
        Re: Ricoh C901s
        Originally posted by afterhours
        Hello,
        Please see attached description
        cheers
        SP3820
        SP3821
        please see attached description
        • afterhours
          • Mar 2017
          • 152
          Re: Ricoh C901s
          Thank you. How can I figure out which developer has too much toner?
          Im a Loser Baby!!!
            • 37739
            Re: Ricoh C901s
            SC367 D TD sensor (Vt low) error: Y
            • afterhours
              • Mar 2017
              • 152
              Re: Ricoh C901s
              @Butcher...
              You Da Man!!!
              That worked.
              And thank you slimdog. It does look like the proble. Was yellow.
              Im a Loser Baby!!!
              • afterhours
                • Mar 2017
                • 152
                Re: Ricoh C901s
                I am now getting a sc333. I've vacuumed the cyan toner tube, I made certain the toner bottle spins as well as the toner pump clutch engages. Any thoughts? Should i replace the developer? The customer apparently put after market toner in the machine.
                Im a Loser Baby!!!
                • davel
                  • Oct 2011
                  • 1113
                  Re: Ricoh C901s
                  yes change dev and charge customer for being stupid enough to put shit toner in a production machine.
                  • butcher
                    • 48
                    Re: Ricoh C901s
                    Hi Mate,
                    Its the yellow unit.
                    • afterhours
                      • Mar 2017
                      • 152
                      Re: Ricoh C901s
                      Hi Mate,
                      Thank you my Friend. Im ordering yellow developer.
                      Im a Loser Baby!!!
                      • afterhours
                        • Mar 2017
                        • 152
                        Re: Ricoh C901s
                        Replaced Cyan developer. Still getting sc333. Any other ideas?
                        Thanks for the help.
                        Im a Loser Baby!!!
                        • afterhours
                          • Mar 2017
                          • 152
                          Re: Ricoh C901s
                          Im a Loser Baby!!!
                          • TonerMunkeh
                            Professional Moron
                            • 3863
                            Re: Ricoh C901s
                            SC333.pdf
                            Might be a blocked toner supply tube. Procedure attached.
                            Hit it.
