Ricoh Wide Format MPCW2200 | Door Open Indicator
  • KWAN
    • Jun 2018
    • 2
    [Error Code] Ricoh Wide Format MPCW2200 | Door Open Indicator
    Changed printhead K , but machine is showing door open indicator .
    any solution for this issue.
    • 37495
    Re: Ricoh Wide Format MPCW2200 | Door Open Indicator
    Have you tried input check SP 5803 to identify which door sensor?
    • mikadonovan
      • May 2008
      • 2931
      Refer to bulletin D124-008, the MBU is probably blown.
      NEVER ASSUME ANYTHING
