Increase the temperature fusing and decrease the toner in the developer
  • Elias
    • Dec 2019
    • 12
    [Misc] Increase the temperature fusing and decrease the toner in the developer
    hello
    aficio 2020
    I need to increase the temperature in the fusing unit
    how to reach the service mode .
    thanks
    Re: Increase the temperature fusing and decrease the toner in the developer
    Originally posted by Elias
    hello aficio 2020 I need to increase the temperature in the fusing unit
    and decrease the toner in the developer how to reach the service mode . thanks
    what issues are you having?
    are you using compatible toner? (non-genuine OEM)
    are you a tech or end user?
    I wouldn't mess with toner concentration in the dev unit that is controlled by the TD sensor, screwing with that will cause problems.
    is the toner flaking off?
    what are your media settings.
    ALL fuser setting will be included in your service manual
    please post errors and copies of print problems
    • Elias
      • Dec 2019
      • 12
      the copie is so dark and when the weather is cold, the fusing doesn't fix the toner very well on the paper, it is erased.
      the toner is compatible,the copie is clean, no background.
      • davel
        • Oct 2011
        • 1086
        Get your machine serviced by a trained tech, use OEM toner or update the dinosaur.
          • 36986
          If you do not know how to get into service mode on this dinosaur, you should not be attempting to repair any Ricoh.
          • fshead
            • 2356
            ahhh JUST do a complete memory clear and close the danm windows
              hope he has the BC for this machine!
              • fshead
                • 2356
                i doubt he evens knows what that is.............
                Another wannabe tech if you ask me...................
                at least buy a manual and look thru it is my mindset
