Ricoh Aficio mp c4501
  • cliffhangers
    • Feb 2010
    • 242
    I'm geting problem to repair error code sc531 on ricoh mp c4501 I have change all three fan bet the code still came up after making some few copy.when I just on the copier I can copy up to 150 duplex copy bet when it get hot the error sc531 came up.when I off the copier and on the code disappears when try to copy the code cames up again.please I need help to solve this error.Thanks in advance.
    • 37377
    Re: Ricoh Aficio mp c4501
    Which 3 fans did you replace?
    • cliffhangers
      • Feb 2010
      • 242
      I have change the front left the right back and the small motor fan under the front left hand.
        • 37377
        Left hand or right hand. The normal use is your left and right as you stand in front looking at the machine. There are 2 fans that circulate air over the fusing. One is the high speed sirocco fan on the upper right that blows air into the front of the fusing unit cavity. The other is the fusing exhaust fan. It is located near lower right rear at the bottom of the plastic ducting in back of the IH inverter board.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          I think these two fans are behind left cover where finisher brackets go where laser unit is I THINK
          Regards Mark
          • fshead
            • 2361
            A lot of times both those thin filters are clogged and both impede air flow,and they sit near the laser unit so i like that area to have good cool air...
            Maybe it does or doesnt relate to the laser board from overheating with the sc 101 codes over time..
            I rather be safe.
            • cliffhangers
              • Feb 2010
              • 242
              I change the 2 fan standing in front right and the 2 fan standing behind left and the code keep caming up after 1 or 2 copy.done know what to do now.please any other way.
              • mikadonovan
                • May 2008
                • 2931
                I have had this one fail multiple times. The fan blades actually break causing abnormally high temps in the fuser area. This will also cause IH coil failure.
                NEVER ASSUME ANYTHING
                • fshead
                  • 2361
                  I HAVE never seen a NASHUATEC RICOH BOX B4..................
                  • mikadonovan
                    • May 2008
                    • 2931
                    That's a really old sticker, but it has our name and number on it. I haven't worked on a Nashuatec in like 20 or 25 years.
                    • fshead
                      • 2361
                      ok
                      it had me a bit confused.................
                      I remember seeing some in the field in the 80s/90s..
                      • cliffhangers
                        • Feb 2010
                        • 242
                        I have discover the error was caming from one of the 4 fan at the laser box one of the fan get stock.Thanks for your support.
                        • fshead
                          • 2361
                          if you dont have parts manual in the future check all the fans before thinking it is more than what it is
