ricoh mp c4000
  • cliffhangers
    • Feb 2010
    • 243
    ricoh mp c4000
    I 'm working on ricoh mp c4000 that was given dack screen and I change one resistor R294 and it came well bet with head drive error I try to enter system mode it was not going so I have to remove the head drive and format it out of the copier and now I 'm getting error code 995-01.what can I do to clear this error?thanks in advance.
    • 37641
    Re: ricoh mp c4000
    NVRAM Replacement error
    1. Install the previous NVRAM.
    2. Input the serial number with SP5811-004, and turn the main power switch off/on.
    Defective BICU
    If you had a service manual you could have looked this up on your own.
      • 37641
      Re: ricoh mp c4000
      You might have a defective polygon mirror motor.
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Re: ricoh mp c4000
        I'll bet that was the ORIGINAL fault....gawd knows what he's done now...Bush mechanic..!!!
