C4503 vs. C4504 similarity
  • JonManchester
    Technician / Shop Manager
    • Aug 2013
    • 103
    How many parts are the same in a C4503 machine and a C4504 machine. I know the itb cleaner and the pcu's are but wasn't sure about other parts, Thanks.
    Live for something or die for nothing.
  • fshead
    • 2376
    Re: C4503 vs. C4504 similarity
    i have yet to see any 04s but would assume knowing rico suave the boards will be different.........
    • skinnyb
      • Jul 2008
      • 291
      A lot of the consumables are compatible. Several are different. The pressure roller and bearings are the same but sleeve different. all feed rollers, pcu, (dev units different), itb cleaning unit, transfer belt (belt itself), ptr is different,
      Sent from my LM-V405 using Tapatalk
      • JonManchester
        • Aug 2013
        • 103
        Thanks Guys, much appreciated.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Only same parts is itb cleaning assy and feed rollers and a compatible drum kit.
          DON'T TRY TO FIT TRANSFER UNIT OR PTR ASSY YOU WILL GET C/Q PROBLEMS
          You can fit 04 oem pcu's into 03 but not 03 to 04
          Regards Mark
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            Toner supply units are the same part number for '03 and '04.
            • ABS tect
              • Sep 2013
              • 511
              Whats the difference on the PCU's?
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                The parts within the PCU are the same ie drum, blades, charge etc but the frame is different but if you order the latest part number oem 04 pcu they will fit into 03 but not 03 into 04. The 04 pcu's are cheaper from ricoh than the 03 series pcu's
                Regards Mark
                • ABS tect
                  • Sep 2013
                  • 511
                  Developer units the same?
                  • skinnyb
                    • Jul 2008
                    • 291
                    Developer units definitely different. I've tried. Pcu themselves are the same.
                    • ABS tect
                      • Sep 2013
                      • 511
                      Hmm interesting.... I'm about to be getting into the '04 series and was hoping to buy '03 for the guts to replace.
                      Good to know... Now is the actual developer powder different? I've come across some generic toner that says you can use in both 03 and 04... So was curious if the toner ingredients are the same wouldn't the developer also be?
                      • davel
                        • Oct 2011
                        • 1107
                        Toners are the same.
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          Developer units NOT the same
                          Regards Mark
                          • Klydon
                            • Mar 2009
                            • 243
                            Given the issues I have seen at times with 03 series devo units, I would not be putting those into a newer machine and instead want the newer version of the devo units. PCU's are fine as others have mentioned.
                            Just my two cents.
                            • rbalker
                              • Feb 2018
                              • 1
                              I found that it makes a significant price difference in the 30/35 ppm models. I'm not sure if the PCU's are exchangeable between the 04 and 03 series for those models.
