Scan to folder on mac stopped working
  • JayPaul
    • Oct 2012
    • 305
    #16
    Re: Scan to folder on mac stopped working
    Just to add to this, I have now remoted into both macs on that site. They are setup identically, both on the latest 10.15.3 (I think that was the version). Tried setting the folder back up again, tried it with a different name, unshared and reshared etc
    If they both didn't work then I could start to suggest scan to usb or get a nas drive or something but the fact 1 works normally and the other doesn't pretty much ruins that.
    I also can't have a folder setup somewhere and shared to the mac that doesn't work because they don't want any scan folder near another because of confidentiality.
    I'm not that comfortable doing all that sudo text on the mac so would really rather not go down that route.
    Then as for telnet, I guess I don't have to change anything that way because the copier can already scan to several windows pc's and a mac so it must have the correct settings?
    • Brianneoe
      • May 2015
      • 322
      #17
      Hi JayPaul, I believe your problem has to do with "Packet Signing" being active on one MAC and off on the one that works. Running a MAC command line is as easy as a PC. At the desktop on the MAC press the "command,shift, A"keys at the same time. That will bring up the App folder. Scroll down to the "Utilities" folder and double click the "Terminal" app in that folder. When you paste this line cat /etc/nsmb.conf and hit the return key you should get a reply of this
      signing_required=no
      IF it =yes then packet signing is turned on. You can always reverse this by changing "signing_required=no" to "yes"
      If packet signing is turned on you will need to turn it off for SMB from the copier to work. At the same window just copy\paste the below command line and then the return key.
      sudo -s
      echo "[default]" >> /etc/nsmb.conf
      echo "signing_required=no" >> /etc/nsmb.conf
      Type in " logout " and you will get a save "yes or no" Type in yes and exit out. Reboot the MAC and go back to the terminal app and paste in cat /etc/nsmb.conf to confirm that packet signing is now off. Now run your test for scan to folder.
      Good luck
      • Brianneoe
        • May 2015
        • 322
        #18
        I ran into this issue again yesterday and went back to my notes. To confirm if packet signing is on or off the command line should start with sudo -s cat /etc/nsmb.conf
        Sorry if you ran my last post and received "no such file or directory" message
        The correct command line to turn off packet signing
        sudo -s
        • JayPaul
          • Oct 2012
          • 305
          #19
          I will try that at some point. I'm kind of dragging my heels a bit with them because the sales person is very friendly with this customer and ages ago it started out as 'can you just help this customer with some networking stuff, no charge for it, just as a favour' and that customer has phoned me so many times with requests for stuff their IT should be doing.
          My hope is that because it is taking me ages to do this they will be less keen to phone me again in the future with annoying requests.
          You seem to know a lot more about this than I do so I have faith typing in the commands you have written will fix this issue for me.
          I will come back to this once I have tried it and let you know of my success (or failure)
          • Shadow
            PHD in Sh!t Disturbing
            • Sep 2011
            • 455
            #20
            With the security changes made to Windows 10 in the last couple years, scan to folder was not a priority in passing along the information to manufacturers.
            I have had techs call me about SMB working on one PC, and not working on another one in the same office. After many questions and having them check the versions, one was Pro and the other was Home.
            At the time Pro worked with SMB and Home did not, after some emails to Microsoft (bata tester) a new update enabled the SMB features for Home Edition.
            Information that would have been more relevant had it been released to the manufacturers of of Multi-Function Devices.
            I came about the Mac OS information with regard to the SMB issue after a customer called stating that the scanning no longer worked after they updated the Mac computers.
            I updated and tested with my own Mac and it no longer worked as well. I started digging in deeper to the changes abd updates to the New OS and found that one of the first things done was to disable the SMB function. The biggest reason for disabling SMB1, for either operating system was the Crypto Viruses. These Viruses were using a loophole in SMB 1 to enter and attack the computers operating system and Encrypt Files.
            By enabling SMB1 on a Windows 10 computer, and enabling SMB on a Mac computer, you are in fact Eliminating Security Protocols set in place by the software manufacturer. This is a risky venture that I would not recommend to any one, unless you have a Signed Agreement with your customer. Should they become infected with any type of virus and its shown to have entered due to a Security Protocol having been disabled, you could be held liable for any damages should the customer press the issue.
            $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
