I need c2503 Firmware
  • darwinabad
    • Jun 2014
    • 10
    Hi, I have a problem with a Ricoh c2503, random codes and sometimes the copier shows a message requesting a user key, the customer restart the copier and the problem disappears.
    I think is a software problem.
    Someone can help me with the firmware
    thanks!
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: I need c2503 Firmware
    thanks!
    Try user copier tech for firmware
    Regards Mark
      bfore that you need to determine WHAT is causing the issues.
      firmware is NOT a fix all
        • 37652
        Why don't you post what the codes are that you are getting. We can then let you know what you need to fix. To me it sounds like you have some one playing games with the machine.
        • darwinabad
          • Jun 2014
          • 10
          thank you for your responses, in this machine I see 991, 997, 442, 816-90, 816-01, 816,26, 553-04, 202, 670 all codes in three days
          Iwill change the hard disk
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            You have some strange errors could try before any parts
            Clear nvram NOT 1 & 2 but all the others.
            Format hard drive
            Update firmware
            Regards Mark
              • 37652
              Most of those Service Codes are related to Energy Save or recovering from energy save. Since a lot of the off timers default to 1 minute, if they have not been changed, the Energy Save system can malfunction. Change to where there are no two things timing out at the same setting. Set them to sequentially time off. Application first then auto log off if User login used and finally power down.
              • darwinabad
                • Jun 2014
                • 10
                Yes, just that had thought, since the error happens when you wake up from energy saving(in most cases)
                • fshead
                  • 2378
                  tell machine :just keep working" dont sleep"
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    Set System SP 5-191-001 to 0 (Power Str Set)
