Ricoh MPC4503 with Bridge Unit and SR3140 torn edge and wrinkling
  • bdesire
    • Oct 2012
    • 62
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Ricoh MPC4503 with Bridge Unit and SR3140 torn edge and wrinkling
    This is usually the fuser did you replace oem sleeve assy & oem pressure roller
    Regards Mark
    • mikadonovan
      • May 2008
      • 2931
      Since you included the finisher type in the post title, I have to ask. Have you disconnected the finisher and tried printing without it? If all is good, then you may have to adjust the angle of the finisher entrance guide. They get bent easily and will cause misfeeds.
      NEVER ASSUME ANYTHING
      • fshead
        • 2356
        did you try running legal or other trays?
        try running not to sorter?
        • fshead
          • 2356
          did you open a fresh ream of paper and run?
          • bdesire
            • Oct 2012
            • 62
            Yes I ran a fresh ream of paper, however I will go back with a different brand and see if it makes a difference.
            • bdesire
              • Oct 2012
              • 62
              The only tray that gives any trouble is the first tray which is letter long edge feed only. I ran it without the bridge and finisher with a small amount of wrinkling but no tear in the paper edge.
              • bdesire
                • Oct 2012
                • 62
                Can I get a little more info on adjusting that guide. Thanks
                • bdesire
                  • Oct 2012
                  • 62
                  Yes all OEM parts have been replaced. It's just uncommon maybe two or three out of a ream will be damaged.
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    If only happens on tray one would of been good to see some samples but could be feed rollers and limiter
                    Regards Mark
                    • mikadonovan
                      • May 2008
                      • 2931
                      You bend it up or down until the paper is feeding in without issue. It's just pot metal.
                      • thurmmy
                        • Aug 2016
                        • 102
                        You could also try loading long edge first in another tray and see what happens. Process of elimination.
                        • bdesire
                          • Oct 2012
                          • 62
                          Long edge first in another tray works without issue. All feed pulleys for that cassette have been replaced.
                          • JDYAL
                            • Sep 2008
                            • 186
                            Is there a lot of paper curl once the paper exits?
                            • bdesire
                              • Oct 2012
                              • 62
                              Very little curl if any.
