Ricoh mp7502 sc204 error
  • edi1907
    • Dec 2015
    • 15
    Hello friends!
    I have a mp7502 machine. When I take print it gives a error and it has written auto reboot has been completed. When I check from sc history, it shows sc204. I changed Polygon mirror motor but the problem continues still. What is your advice for me please?
  • MIKON
    • Jul 2015
    • 186
    Re: Ricoh mp7502 sc204 error
    Try this remove the drum unit.Pull on the grounding spring on the rear of the drum unit to extend it a little.Then clean the frame where the spring contacts the frame,
      Originally posted by edi1907
      Hello friends!
      this thread might help you:
      ricoh mp6002 sc 204
      • farhad
        • Apr 2020
        • 40
        this error means you macine cannot process signal on potantial sensor and potantial sensor processed referans on drum
        OK?
        you can change drum to fix this problem
