C5503 K developer
  • mikadonovan
    • May 2008
    • 2931
    C5503 K developer
    Hi, All. Has anyone actually changed the developer in a black c5503 dev unit? If so, what developer did you use? I just replaced one and cleaned out the old one (toner/dev chunks causing lines). I have a ton of old developer from previous models just going to waste, and I figured I might try to refill the old unit with a "similar chemistry" bag of developer.
    NEVER ASSUME ANYTHING
  • fshead
    • 2376
    Re: C5503 K developer
    AS I have used mpc6003 toners in a mpc3003 by shaving bottom of housing and swapping chips that toner is the same.
    I have changed mpc3003 K and cyan developer when seeing major clumps/chunks in dev tank.
    I have not tried type 24/28/19 or others but developer for the mpc3003..
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Hi mikedonvan
      Dev units are cheap I've never tried any other model developers in the 03's ricoh UK only sell dev assy but I know you can get dev from China but wouldn't recommend it.
      Regards Mark
      • 8T2
        • Aug 2015
        • 257
        I've used the old B2309640/60/70/80 in pretty much everything by now and can't remember running into issues, but could just have been lucky too I guess.
        Edit: have not used them in 03 range or newer, just remembered now what a pain those Dev units are to crack open.
        Sent from my WAS-LX1 using Tapatalk
