Savin/Ricoh MP C3333 SC 492
  • thurmmy
    • Aug 2016
    • 102
    I've got kind of a weird problem. It started out as a yellow toner end/bad toner pump problem. I put in a cyan pump, it was what I had, and that resolved the no yellow toner problem. After that I went to do ACC and my chart printed out had black, some magenta but no cyan or yellow. Removed pcu's and they all had toner in the hoppers. The SMC says I am getting sc 492s. I can print out the chart on the ACC 1st will come out bad, immediately do another and it comes out perfect. Print out another, its bad. Like every other one. I swapped out the ITB unit, replaced the H.V.P.S. with new one. Still the same. The customer came in overnight and printed say 10 color prints from computer, 1st 5 were good then next 5 no color. Also I had put in new paper transfer roller. There is no problems with B/W copies/prints. Any ideas? I have looked at the contacts for ITB and don't see anything abnormal.
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Savin/Ricoh MP C3333 SC 492
    Mpc3333 never heard of that machine quote correct machine and if you have samples would help
    Regards Mark
    • thurmmy
      • Aug 2016
      • 102
      The C3333 is a little brother to the C5000.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Can't wait to see a MPC3333 I think you mean mpc3300 best to know your machines 1st sc492 is a transfer assy problem still good to post samples we would help the guys out a bit more.
        Regards Mark
        • thurmmy
          • Aug 2016
          • 102
          MP C3333 samples.pdfsample
          • thurmmy
            • Aug 2016
            • 102
            Savin version of C3300
              • 37556
              [ATTACH]45090[/ATTACH]sample
              You may have a problem with the laser shutter. Or the lift for the color transfer rollers. Considering that the MP C3300 launched 10/14/2008 you might be better off to replace the dinosaur. The need repair parts might not be available.
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Good idea
                Also check white grounding cables at rear of itb assy we've had a couple wire's shorting out giving funny codes
                Regards Mark
                • thurmmy
                  • Aug 2016
                  • 102
                  I guess that's possible but wouldn't I be getting a SC for that. Also, I know my machine, I installed it new and have been working on it for 11 years.
                  • thurmmy
                    • Aug 2016
                    • 102
                    As stated 2 different ITB units. Its weird that it happened after replacing toner pump.
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      Slimslob has given some good advice check it out and may be try another transfer unit
                      Regards Mark
                        • 37556
                        Color transfer rollers not being lifted could cause SC492. It will definitely cause the second page of the samples you posted.
                        • thurmmy
                          • Aug 2016
                          • 102
                          This makes the most sense, thanks. I will be back over there in the morning.
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            Sorry missed the ITB replacement you sure you haven't damaged or knocked something on rear frame where pumps are then.
                            Regards Mark
                            • FrohnB
                              • Jul 2017
                              • 1919
                              C3333 is the Savin Number for the Ricoh C3300.
                              Omertà
