scan to e-mai (gmail), MP2501,sp3600sf
  • Marwanalhajbi
    • Jul 2018
    • 72
    I'm trying to make scan to e-mail using smtp server from gmail,but there is no feature as in mp c printers called(Use secure connection (SSL) ) i have tried to enable it from Security category but no results,
    any suggestion?
  • sandmanmac
    • 3981
    Re: scan to e-mai (gmail), MP2501,sp3600sf
    any suggestion?
    There is "use secure connection" on the machines, but it may not be available in the WIM. The older units it was only available in user tools (under smtp server)
    In order to setup scanning using Gmail requires one of 2 settings be made in the google account :
    Either enabling "allow less secure apps", or turning on 2-step verification and then creating an "app Password" for the machine
      • 37483
      The models mentioned may not support TLS. Standard gmail SMTP server requires support for TLS. You may find the following link helpful.
      Send email from a printer, scanner, or app - G Suite Admin Help
      • kplow1986
        • Nov 2013
        • 41
        For those model that didn't support SSL, there is a software call email relay.
        link here E-MailRelay download | SourceForge.net
          • 30203
          Allows you to send messages to Gmail or G Suite users only. This option does not require you to authenticate.
          Requirements
          Sending limits Per-user limits apply. This option restricts sending messages to only Gmail or G Suite users.
          Anti-spam filters Suspicious emails might be filtered or rejected.
          Fully qualified domain name of SMTP service aspmx.l.google.com
          Configuration options
          Port 25
          TLS not required
          Dynamic IPs allowed
          Can only send to Gmail or G Suite users
          Authentication requirements None
