aficio mp c 305
  • Marwanalhajbi
    • Jul 2018
    • 72
    aficio mp c 305
    it works just fine throw bypass but in try one it jam ,one paper stuck on fuser and the other jam on the try,it shows like they met in front of itb then it shows j057
    any suggestions,thanks alot
    Re: aficio mp c 305
    get a service manual
    make sure your paper size and type match what the machine thinks it has in it
    • FrohnB
      • Jul 2017
      • 1919
      Re: aficio mp c 305
      +1 on this. Make sure the size isn't "hard set" in user tools.
      Paper loaded correctly?
      Make sure the little gray end fence and your side fences are in correct position (should be touching the stack of paper).
      Feed Roller Cleaned? Transport sensors cleaned?
      These are literally the only things it could be!
      Omertà
        • 37533
        Re: aficio mp c 305
        J057 is a trail edge lag. Either the paper in tray 1 is longer than what the size is set for or you are have problems with paper separation on tray 1.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Re: aficio mp c 305
          +1 all replies sound to be likely problem
          Regards Mark
          • nirvaner
            • Sep 2013
            • 5
            Re: aficio mp c 305
            Hello everybody.
            I had this problem the other week, and after tests and more tests, exchanges and more exchanges, I solved the problem with a paper feed clutch. There is an engine that feeds the paper circuit and next to that engine is a series of clutches, the paper feed was the one that was causing this. He pulled a leaf and didn't hang up in time and started pulling the second.
            • DBB185
              • Jul 2018
              • 4
              Re: aficio mp c 305
              Is there an easy wat to get the paper feed clutch out? It looks like it is behind the PSU and you basically have to remove everything to get to it.
              • nirvaner
                • Sep 2013
                • 5
                Re: aficio mp c 305
                yes it is a bit annoying to get there
                1. Controller box
                2. PSU
                3. Fusing motor
                4. Paper transport motor
                5. HVPS (PCDU)
                6. ITB
                7. Paper transport unit
