By pass tray locked
  • Tech18
    • Jun 2018
    • 23
    By pass tray locked
    Hello all
    I have mpc4502 with a key lock on by pass .. can't use it ..
    How do I unlock it ..?
    Thank you
  • mikadonovan
    • May 2008
    • 2936
    Re: By pass tray locked
    User tools.
    NEVER ASSUME ANYTHING
    • dpoutz
      • May 2011
      • 78
      Originally posted by mikadonovan
      User tools.
      if its like the mpc5503 in paper tray setting you set tray to auto paper select I believe
      • FrohnB
        • Jul 2017
        • 1919
        User tools --> System Settings --> Tray Paper settings --> go down one page and select "Bypass Paper Type" --> Right-bottom hand corner Select YES for "Apply auto paper select".
        Omertà
          • 35061
          Are you meaning that someone actually installed a physical locking device on the bypass tray. If so, you may need to get a locksmith to pick it or drill it out for you.
          • Tech18
            • Jun 2018
            • 23
            Cool, thanks
            I will try that .. thought i did but will double check
            • Tech18
              • Jun 2018
              • 23
              Haahaaa.. No
              There is a "key " on bypass tray at ocontrol panel ..
              • DRichard
                • May 2008
                • 482
                Originally posted by Tech18
                Haahaaa.. No
                Try turning the key. It used to work when I played Zork.
                "Enjoy every sandwich."
                -- Warren Zevon
                • ridgemill
                  • Sep 2017
                  • 172
                  Haahaaa.. No
                  All this means is that the tray will not be selected during auto-tray select. You can still manually choose the tray through the printer driver and copy screen.
                  Most of the time the bypass tray is used for unusual paper types, so it comes pre-'locked'.
                  • Tech18
                    • Jun 2018
                    • 23
                    No, if the lock key is on , I can't use it at all .. it will stop and says jams ..
                    It is all good now ..
                    I set it to "Auto paper select"
                    Thank you all ..
                      • 35061
                      Thank you all ..
                      I get the impression that you are not a trained Ricoh customer engineer. Call you nearest authorized service center.
                      • Tech18
                        • Jun 2018
                        • 23
                        No thank you ..
                        I got it ..
                        • JoshuaHann
                          • Dec 2019
                          • 2
                          Are you sure about it that a locksmith is the right choice for the problem?? When they can resolve the issue on their own.
                            • 35061
                            Go away grave robber. This thread is over a year old.
