ricoh mpc2051 error code sc315
  • Eeric
    • Nov 2014
    • 8
    [Error Code] ricoh mpc2051 error code sc315
    hi all, i got 1 mpc2051 machine show sc315. i do fully service n exchange pcdu yellow , hvt cb, motor drive unit (hvt connector on it), bcu, controller board, also cable from hvt to bcu but still got sc315 when turn on machine . wat else can i do?
  • Polarbear
    • Feb 2012
    • 1070
    Re: ricoh mpc2051 error code sc315
    Hi
    Looks like the BICU is all that is left.... I have had strange faults with faulty nvram before, so do not leave that out of the equation either.
    Press the GREEN button!!
    • FrohnB
      • Jul 2017
      • 1919
      He replaced BICU he said. (he said bcu).
      Did this code show up before or after replacing the yellow unit?
      The only thing it seems you didn't mention is the Main Power Supply. Try replacing that. Could also try replacing the HVT TTS board just in case.
      Otherwise, you may be looking at a broken wire somewhere, or something not making contact properly on the PCU. Check your drum contacts and what not.
      Omertà
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        +1 try another pcu from other colour. If it's a pwb it would be hvps not bicu
        Regards Mark
        • Eeric
          • Nov 2014
          • 8
          thx for help ,i will try it
