Ricoh MP 3053 Firmware
  • OBI
    • Sep 2019
    • 6
    In need of the latest firmware for MP 3053. Any assistance would be appreciated.
    • 37480
    Re: Ricoh MP 3053 Firmware
    Forum Rules General Rule 5. Discussion of illegal activities such as software and music piracy and other intellectual property violations are not allowed.
    Ricoh firmware is the intellectual property of Ricoh.
    • sandmanmac
      • 3981
      Your Profile indicates you've been at this since 1990. Seems to me you'd have a lot of experience to assist others in resolving issues, yet you've shown no inclination to do so.
      You'll find that your requests for things like this will be much better received when you give back to the forum
        what problems are you having that makes you think you need firmware??
        • OBI
          • Sep 2019
          • 6
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            I would start with back up address book
            Format hdd in service mode
            Clear nvram NOT 1 and 2
            Update ALL firmware
            Reinstall address book
            Setup machine with fresh ip address not wsd and not Windows driver
            Should be ok after that.
            Regards Mark
              • 37480
              You may need to replace the HDD. Also if JAVA is installed and active and you are not using any JAVA apps, disable it. It takes roughly 4 to 8 minutes to complete initializing and slows everything else while doing so, blocks access to most User Tools except the counter and blocks access to items in SP modes.
              • sandmanmac
                • 3981
                Excellent advice from both Slim and mga!
                You see.... Most/ all of the issues are not even F/w related - except possibly (likely) the scanning part (SMB v2/3 support) which I will refer you back to my original post
                • OBI
                  • Sep 2019
                  • 6
                  Thanks everyone for your suggestions. I haven't had the chance to work on the machine yet due to coronavirus. I will update soon as I can.
