1106
  • nenadbigovic
    • Aug 2014
    • 9
    [Jamming] 1106
    Hi, I have a problemon 1106 ricoh pro, paper jam on registration and show Paper misfeed (J069). When copying is slow, paper rarely stops, sometimes when I start printing paper stop. I changed registration motor and nothing, anyones help? Tanks
    rarelyrarelyrarelyrarely
    • 37490
    Re: 1106
    J069 is a relay sensor lag jam. Most likely a dirty or bad sensor. Could also be paper that is slightly too long.
    • nenadbigovic
      • Aug 2014
      • 9
      Re: 1106
      thanks, where is on a mashine that sensor?
      • mikadonovan
        • May 2008
        • 2931
        Re: 1106
        If you are going to have even the slightest chance of successfully repairing a piece of equipment like this, you need a service manual.
        NEVER ASSUME ANYTHING
        • nenadbigovic
          • Aug 2014
          • 9
          Re: 1106
          I have service manual, but I clean double sensor and registration sensor, but nothing, same
            • 37490
            Re: 1106
            It is the upper relay sensor, not the double feed sensor, not the registration sensor.
            • tsbservice
              Field tech
              • 8016
              Re: 1106
              If you have SM just follow troubleshooting for this code. Use find to search for unfamiliar parts, sensors, etc. Start with easiest tests/checks not with motors(maybe last).
              • nenadbigovic
                • Aug 2014
                • 9
                Re: 1106
                mashine is do 1 by 1 copy, but in 15, 20 copyes stops, sometimes 5, sometimes 25 copyes with no problems
                  Re: 1106
                  sounds like you aren't a trained tech on this product.. .sounds like you are in over your head.
                    • 37490
                    Re: 1106
                    Service Manual - Replacements and Adjustments - Paper Feed - 3.10.17 LCT RELAY AND RELAY SENSORS shows a very clear picture of the sensor and its mount bracket.
                    • nenadbigovic
                      • Aug 2014
                      • 9
                      Re: 1106
                      I use paper tray 1,2,3
                        • 37490
                        Re: 1106
                        Upper relay sensor is for trays 1, 2 and 3.
                        • farhad
                          • Apr 2020
                          • 40
                          Re: 1106
                          hi j069 in ricoh 1106 means UPPER RELAY SENSOR LAG
                          1. check your machines relay and registration sensor
                          2.check your machines relay and registration gears and timing belt from back side the machine
                          3.change registration motor on your machine
                          I'm 16 years Technician and very time I see this problem
                          Rest assured, it's none other than that
