MP C3500 Copier Duplex Problem
  • tphan2k
    • Jul 2025
    Does anyone have experienced with MP C3500 fail to print/copy duplex letter size?
    Mine does the 11X17 ok but fails to duplex the 8.5X11 with either printing or copying option. Any help will really appreciated.
  • KopyKat
    Nurse Ratched of Repair
    • Nov 2008
    • 365
    I saw this once on an MP900 when in User Tools the tray for letter was set to No Duplex mode. Not sure if MP C3500 has the same setting.
    sigpic
    Relax! This firmware injection won't hurt...but it will take 45 minutes.
    • Star
      Ricoh Tech
      • 127
      I'll put my money on KopyKat's answer, LOL!
      Regards
      • Eric1968
        • 2458
        Or the media type for that cassette is set to thick paper?
        • tphan2k
          Kopycat, Eric1968.
          Under menu Copying in Duplex mode 2 sided was selected and the paper type- plain paper was selected. Both trays were set to automatic.
          The 11x17 was printed fine in duplex.
          • KopyKat
            • Nov 2008
            • 365
            So you still can't duplex letter? Have you tried putting the letter size in the other tray? That will isolate it to a setting for the tray. Do you get any error messages? Try setting the paper size in the user tools instead of the automatic size selection...I've seen problems with the size detection. Beyond that, perhaps you have a glitch in the firmware...reload firmware.
            Please update us on what the fix is when you find it. I'm very curious now.
            sigpic
            • knightfall
              • Jul 2006
              • 633
              when you say failed to print do you mean it jams or doesnt print at all?
              Get your facts first, and then you can distort them as much as you please.
              • Ricoh-ono
                • 338
                There was a bulletin for rattling in the paper separation area. One or both of the springs would come loose on the duplex driven roller. I have had duplex jams caused by this. I can't explain why 11x17 is working, other that there may be a lower set of rollers driving the paper through the duplex.
                Do what you can, with what you have, where you are. ~Theodore Roosevelt
                • tphan2k
                  Problem Found
                  Thanks to Ricoh-ono. You gave me the exact information I needed. I apologize foe a late response. Now, if you kindly can point me to where I can buy the Plate springs P/N B2239004.
                  Thanks for your help.
                  • Fearless V K
                    • 620
                    You should probably just try to find an old spring from a parts machine that will fit or can be modified to fit. It would be faster, cheaper, and easier than ordering and waiting for a part.
                    Don't take that toner with me!
                    • tphan2k
                      I still have the srpings. I just need to get the adapter plate to hold the roller in place.
