Lanier LD365C / Ricoh MPC6501
  • mtcchuck
    • Oct 2016
    • 50
    [Error Code] Lanier LD365C / Ricoh MPC6501
    Good afternoon
    I am looking at a Lanier LD365C with a service code sc534. I believe it crosses to a Ricoh MPC6501. I cannot find a service manual online. Can anyone offer information on this machine? The code appears to be a fan trouble code but that's about all I can find out.
    Thanks,
    Chuck
  • tsbservice
    Field tech
    • 7983
    Re: Lanier LD365C / Ricoh MPC6501
    Search is your friend:
    mpc 6501
      • 37383
      Originally posted by mtcchuck
      Good afternoon
      Thanks,
      Chuck
      Don't you mean that you cannot find it for free? Service-manuals.net has it for $12.99.
      RICOH Aficio MPC6501, Aficio MPC7501 Series Service Manual – Service-Manual.net
      How long has it been since you replaced filters?
      • mtcchuck
        • Oct 2016
        • 50
        I did try searching but for some reason it wont let me go past the first page of the search.
        Correct, I could not find it for free. We are a Kyocera dealer and the Lanier machine was given to our Emergency Management office. I thought id try to help them out. I was just looking for a little help for a 1 time service. thanks for the help
          • 37383
          You are asking for many headaches helping your Emergency Management office with this particular model machine. Unless all bulletins have been applied and the machine setup properly, this model is known as a toner belching beast. After making sure that all spewed toner is removed from the Development Unit, PCU and ITB and the ID sensor assembly, apply the SP changes in the attached.
          • mtcchuck
            • Oct 2016
            • 50
            Thank you very much for the info. I will give them the heads up about the headaches associated with this model of machine.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Good afternoon
              Thanks,
              Chuck
              This is quite common on this machine most likely paper stuck in fan behind main unit you pull out
              Regards Mark
                • 37383
                Once YOU start helping them with the machine, the headaches will be YOURS. You will be married to the machine until they decide to replace it. If they are not happy with the LD365C while you are "helping them out" your chances are greatly reduced as far as selling them their next machine.
