Scan to USB question c5503
  • mikadonovan
    • May 2008
    • 2931
    Hi, All. I hope you are having a safe and mind-calming day. I have a c5503 that will not recognize the usb flash drive when plugged into the SOP slot. SP 5985-002 is set to "1". 4 different flash drives have been tried, including one that works fine in a c4503 I have in the shop. Am I missing something simple?
    NEVER ASSUME ANYTHING
    • 37452
    Re: Scan to USB question c5503
    Check Printer SP 1110-001 and Scanner SP 1013-001. These were used with older models to enable, set to 1, the USB2.0/SD Slot. If set to 0 the slot is disabled.
    • mikadonovan
      • May 2008
      • 2931
      No printer sp1110 on this model, but scanner sp1013 is still being used. I will check it out tomorrow onsite, maybe. Thanks for the info.
      • sandmanmac
        • 3981
        Hey Mika....
        It could be a SOP screen setting that's the issue - It is on the MP305 that I have here at home.
        Try this:
        UT / Screen Features/ screen device settings / screen USB memory slot / active
        (There's also another one for the SD card slot)
        Hope it helps!
        • tjvincent
          • 280
          I've had customers call for that a few times and usually a simple reboot fixes it.
          • FrohnB
            • Jul 2017
            • 1919
            Insert USB device --> go to scanner screen --> Select "Store File" --> Choose "Store to media device" and hit OK --> Press Start. It will say "Do not remove - Writing", and then give you a "writing successful" message. Tried this on a C4502/ C4503/ MP 2554.
            Not sure if the size of the USB device matters? I used a 30 Gig Verbatim USB.
            EDIT: Didn't realize it said SOP until now, my directions are for Normal Op panel.
            All firmwares up to date? They just released a small batch of firmware for the C3003 and up (System, Printer, Web support and Webuapl - for the NOP and SOP versions).
            Omertà
            • mikadonovan
              • May 2008
              • 2931
              Originally posted by sandmanmac
              Hey Mika....
              Try this:
              Hope it helps!
              Thanks, Sandy. I did not know this either. Whenever I get to go back, I have several things to check now. Stay safe.
              • StephenB
                • Aug 2015
                • 240
                Had this same problem, but on a MP C5502... 2 yrs ago, turned out to be the usb cable that feeds from the front panel to the back of the system.
                Just all of a sudden quit recognizing the usb drive ??? I assume if the panel is moved frequently, can cause cracking in the wire itself.
                It's a standard, but longer, usb type (phone charge cord- available on amazon) easy to test / check, just plug in the new cable on board and try a thumb drive.
                  • 37452
                  That would be the cable with the USB2.0/SD Card kit. With the SOP, if there was a problem with the USB cable the panel would have no communication with the engine.
                  • StephenB
                    • Aug 2015
                    • 240
                    That was not my experience. Everything functioned except when a usb thumb drive was inserted - no recognition. I re-seated the original cable, no good. To test, I used a usb extender directly to the board on back plugged in a drive- was good
                    Replaced the original cable, has been fine since. Perhaps there was limited communication with the old cable. I'm only sharing my solution.
                    • mikadonovan
                      • May 2008
                      • 2931
                      And a simple reboot fixed this one, too. I went ahead and updated firmware while I was there.
