Ricoh IM C3000 jump drive printing
  • dacjkhadley
    • Mar 2013
    • 19
    The manual says that an XPS file can be printed from this machine, but when the jump drive is plugged into the port on the smart panel, the file does not show up. JPG, PDF, and TIFF files will. Any suggestions? Have updated the firmware and even created my own file aside from the clients. No luck.
  • tsbservice
    Field tech
    • 8077
    Re: Ricoh IM C3000 jump drive printing
    Have you tried different USB thumb drives? If no this particular one may be corrupted.
    Worst case scenario machine may need to be initialized.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      I think you will find that a printer language it's not standard if a extra option
      Regards Mark
      • tsbservice
        Field tech
        • 8077
        At first I thought the same but not knowing Ricoh product line led me to search for a manual and it's in user manual where is stated that print from USB thumb drive support XPS format, no asterisks or option mentioned so I' m under impression this is standard function and should work out of the box.
        Of course I might be wrong cuz user documents are not service documents
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Ricoh 417508 File Format Converter Type M19
          I think this is what's needed not standard
          Stay safe
          Regards Mark
          • tsbservice
            Field tech
            • 8077
            Stay safe
            Ahh, thank you for that. Next time I should 🏊 in more known waters
            Stay safe mga
            • Brianneoe
              • May 2015
              • 322
              Without confirming with Ricoh I believe this is the option needed, XPS Direct Print Option Type M37
              Its a SD card style option. I can find no
              documentation yet on it but its listed as a "New" option to the IMC series.
              Google Google..
              XPS Direct Print Option Type M37418405
              Function to print XPS directly from USB/PC, without using driver. XPS is a new XML based document format developed by Microsoft, which is similar format with PDF.
