MP5054 first print (posted on behalf of GeorgeBest due to forum glitch)
  • tsbservice
    Field tech
    • 7981
    Hi,
    Got this MP5054 with a print that is dirty on the first print, as if the fuser is not working correct.
    also few stripes visible, looks like coming from the paper guide.
    After a few prints its doing allright and no problems.
    Only when coming out of standby this problem occurs sometimes, not allways. .
    anyone a clue here . .
    thanks in advance
  • tsbservice
    Field tech
    • 7981
    Re: MP5054 first print (posted on behalf of GeorgeBest due to forum glitch)
    Hi GeorgeBest,
    I'm not Ricoh tech but looks like you have preheat problem(Fuser can't reach speciefied temperature at first copy).
    Can you increase fuser idling in service mode?
    Btw, Hadster how you can manage to reply on this? Due forum glitch when someone use print at end of the title thread is opened in printable view and cannot be answered.
    I was under impression that even Chuck Norris cannot reply, you must be better
    • Hadster
      • Aug 2011
      • 264
      Sorry! I was concentrating on the issue. Simple fix hopefully=clean fuser entrance guides. Also check engine firmware to be at or above 1.11:03.
      Sent from my LG-US998 using Tapatalk
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Hi,
        thanks in advance
        Hi George best
        Are you sure it's the fuser
        What are the pm lifes
        Also try not to use the cheap sleeve film {from China}
        Update firmware
        Regards Mark
          • 37365
          In all likely hood, it is not a fusing problem. The machine is most likely past PM count on the PCU or the HVPSU is bad. Martini were notorious for about a 2 inch lead edge background on the first page when the charge corona was well past PM count and the drum was weak.
            • 37365
            Originally posted by terramobil
            Sorry Slim, MP 5054 is not a Martini, it's a Corona (a really bad name at the moment).
            But the potential problem is still there.
            • GeorgeBest
              • Jul 2009
              • 520
              I swopped the fuser and changed the PCDU !
              No more problems now. . .
              Thanks in advance
              QUOTE=slimslob;1452409]But the potential problem is still there.[/QUOTE]
              • andrewdecruz
                • Jul 2009
                • 74
                Thanks in advance
                [/QUOTE]
                Since you replaced both the fuser and the PCDU at the same time, it is now even more difficult to pinpoint where the problem was in the first place.
