Have a Ricoh MP C3001 that I just updated it with the Ricoh KIT-C3001 TRC Transfer Roller Case Kit. Installed it with no problem closed the right side door and ran copies just fine. Then when trying to open the right side door again, for some reason the transfer case assembly is jammed and only allows the door to open a very small amount and not fully open. Couldn't tell what was holding it from opening all the way, so tugged on it more and finally got it open, but snapped off on the left side or operator side of the machine the black front guide positioning part mounted inside the frame of the machine and the gray stopper-holder separation upper part on the transfer roller unit. For some reason the PTR gets jammed up I'm guessing behind the front guide some how. Can't see why? Can't see anyway to adjust the transfer case assembly to prevent it from getting jammed once the door is closed. Anybody ever encounter this? If so recommendations for a fix?
