MP 3350 Fusing Swivel Bracket Replacement
  • Toner Man
    • Mar 2011
    • 56
    [Misc] MP 3350 Fusing Swivel Bracket Replacement
    Hey Guys.
    Anyone have experience in replacing this bracket?
  • sandmanmac
    • 3981
    Re: MP 3350 Fusing Swivel Bracket Replacement
    Originally posted by Toner Man
    Hey Guys.
    Yup.
    No big deal. It's been a while, and there's a few things that need removing, but it only takes about an hour.
    Glad I could help.....
    • copyaction
      • Oct 2007
      • 991
      • Toner Man
        • Mar 2011
        • 56
        Hey Guys.
        I forgot to mention I need replacement instructions, where do I start?
        • davel
          • Oct 2011
          • 1103
          Start by grabbing screwdriver.
          • Toner Man
            • Mar 2011
            • 56
            Good point, thanks
            • sandmanmac
              • 3981
              C'Mon. The service manual is readily available with a 2 second google search, and as far as I know there's no specific instructions for that particular job.
              Some jobs just require patience and common sense.
              This would be one of those jobs.
              • FrohnB
                • Jul 2017
                • 1919
                Remove fuser.
                Remove back cover.
                Move BICU board out of the way (4 screws and a few connectors need to come off to get it to flop down and out of the way).
                remove the HVPS board (upper left - 4 connectors/ 3 or 4 screws).
                remove the “balancing plates” (big metal circular plate) from drum shaft.
                Remove a couple metal brackets behind that (one has fuser harness and some others resting on top of it.
                move fuser harness connector/ plate out of the way (2 screws).
                theres another metal plate with a gear and belt that will come off next.
                unhook white plastic solenoid linkage .
                remove swivel gear (2 screws and have to finagle it out of there).
                Put back together.
                Service Manuals can be useful too, but not for this part!
                No instructions in manual for this.
                Omertà
                • sandmanmac
                  • 3981
                  Damn! That's impressive, ​and generous Frohn.
                  Props to you
                  I feel like you may have done one of these more recently than I.
                  There's no way I could remember the steps that clearly (or been bothered to list them)
                  • Toner Man
                    • Mar 2011
                    • 56
                    Thanks FrohnB, this is exactly what I need. I have access to the FSD and noticed there was no instructions as you alluded to.
                    • Toner Man
                      • Mar 2011
                      • 56
                      No need to Google, I have access to every Ricoh manual imagined. The concern is minimizing customer down time. So specific instructions were needed.
                      • Toner Man
                        • Mar 2011
                        • 56
                        C'Mon. The service manual is readily available with a 2 second google search, and as far as I know there's no specific instructions for that particular job.<br>
                        Some jobs just require patience and common sense.<br>
                        <br><br>No need to Google, I have access to every Ricoh manual imagined. The concern is minimizing customer down time. So specific instructions were needed.<br>
                        <br>
                        • FrohnB
                          • Jul 2017
                          • 1919
                          Props to you
                          Have done more than I care to count!
                          It was actually one of the first “tests” my boss gave me in my first weeks on a machine in the shop. Handed me the part and a manual and said good luck! Didn’t tell me the instructions don’t exist!
                          So I Studied the manual, couldn’t find it anywhere, and just started digging in. Needless to say, I removed more than I needed to on that first go around, but figured out how to get it replaced! Nowadays I could probably do it in my sleep.
                          Omertà
                          • sandmanmac
                            • 3981
                            Why would you not state the purpose in your original post and save us all some time?
                            "Does anyone have any experience replacing this......" is pretty vague, wouldn't you agree?
                            • Toner Man
                              • Mar 2011
                              • 56
                              True, I must admit it was pretty vague
