Ricoh pro c751
  • omidomidomid
    • Jan 2019
    • 6
    [Error Code] Ricoh pro c751
    Hi everyone
    I am struggling with error code SC584
    what I did so far:
    I changed IOB-BCU-ALL OZON FANS-NEW FIRMWARE-TDCU-CONTROLLER- MEMORY ALL CLEAR-CLEAR ALL PM COUNTER-Z C1- TC1-IPU
    Any other suggestions or others with experience this error?
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh pro c751
    Only thing left is the harness!
    I've attached the P2P for the harness part numbers from the IOB to to ozone fans.
    Hit it.
    • omidomidomid
      • Jan 2019
      • 6
      Re: Ricoh pro c751
      [ATTACH=CONFIG]45719[/ATTACH]
      I changed the CN315 wire string TO ozon fans , but there is still a problem
        • 37550
        Re: Ricoh pro c751
        First off, SC584 does not exist for the Pro C751. In fact the only Production Color model it does exist for is the Pro C7110X. From Gooses Guide for the C7110X:
        Rear Box Ozone Exhaust Fan. PER README FILE Issue began after Engine firmware upgrade. Applying this firmware to machines not installed with the modified fans will cause SC584-00. For machines not installed with the modified fans, upgrade the System/Copy firmware to version 3.02, apply the following SP values, and then turn OFF/ON the machine.
        SP1-945-009 set to 100
        SP1-945-011 set to 100
        SP1-945-017 set to 100
        SP1-945-019 set to 100
        SP1-945-021 set to 100
        SP1-945-052 set to 0
        Now what is the actual Service Code you are getting?
        Second where the hell did you get the idea that performing a memory all clear was going to be helpful. Were you looking at a B/W service manual for SC584 which is a fusing error on B/W and mistakenly ran SP 5801-001 Memory All Clear instead of SP 5810 fusing unit reset. In any case if you did actually run SP 5801-001, Memory All Clear, you have created a whole new can of worms for you to have to deal with. Unless you have the birth certificate, you have created anywhere from 2 to 12 hours or more work getting the color back in alignment.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Re: Ricoh pro c751
          Hi slimslob hope you are well sc584 is in UK proc751 manual.
          But +1 on everything you said. Stay safe and stay well
          Regards Mark
          • omidomidomid
            • Jan 2019
            • 6
            Re: Ricoh pro c751
            I got Backup before resetting 5824 NVRAM UPLOAD
