MPC2503 slightly red glow . . .
  • GeorgeBest
    • Jul 2009
    • 525
    Hi,
    When making a color copy or color print there is a minimum slightly red glow/background !
    I've already changed the PCU and the Developer unit Magente for a new one.
    Still, but less then before, a small glowing red background in the color mode.
    Mostley this sort problems are solved by changing the M unit, not now . .
    Any Ideas? High voltage? ITB? Contacts?
    soon will be visting customer.
    Thanks in advance
    Greetz G
  • ridgemill
    • Sep 2017
    • 189
    Re: MPC2503 slightly red glow . . .
    Is it an even background?
    When replacing the PCU did you re-attach the rear plate? If this is missing it can cause a background to appear.
    Also, make sure you enter the coefficient of the new drum in SP2-005-237.
    It is easy to miss these two, even after fitting these drums a hundred times.
    If the problem persists between different drum units, perhaps a shading error?
    Make sure the white reference, optics, and laser are cleaned. Perform a memory clear on Printer Application, to reset the ACC, then re-perform the ACC and do a test print. If that looks good, do the same with the Copier Application, but make sure you take note of their Copier settings first.
    If you get a chance, either print off the Printer SP colour test pattern, or get the customer to, and post it here.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Originally posted by GeorgeBest
      Hi,
      Thanks in advance
      Greetz G
      Was they new oem parts rear plastic plate near dev gear needs to be on
      Regards Mark
      • GeorgeBest
        • Jul 2009
        • 525
        Yes OEM parts and the plate is on . . .
        • GeorgeBest
          • Jul 2009
          • 525
          Did not do the SP2-005-237 input, easy to miss as you said
          But I've heard that when you change the drum together with the developer the input is not necessary?
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Have you any pdf samples
            Regards Mark
            • GeorgeBest
              • Jul 2009
              • 525
                incorrect
                  • 37447
                  Did the problem start before or after you replaced the Magenta PCDU?
                  • GeorgeBest
                    • Jul 2009
                    • 525
                    before . . . and after
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      I would start with checking all the SP settings for color, cleaning the ID sensors, replacing the cleaning unit and do an automatic color calibration (perhaps this first).
                      • Zeldaman
                        • Mar 2011
                        • 946
                        Hi there!
                        There were some important FW-updates for the 20th METIS-series. First at all: clean the optics & ITB-sensors, update to the newest FW & then do ACC.
                        No sp-input when changing the PCDU, but if you change dev-unit & pcu you must input the sp-code .
                        Greetings...
                          • 37447
                          Then the problem is with the machine not the PCDU. Try your Best to find it George.
                          • GeorgeBest
                            • Jul 2009
                            • 525
                            Eventually I changed the SP2005-237 in another value then was given. Gave it a higher value, the red background disappeared.
                            thanks for the input everyone
