Ricoh pro c5100 error code sc538-01
  • Chimatoner
    • May 2020
    • 4
    [Error Code] Ricoh pro c5100 error code sc538-01
    Ricoh pro c 5100 showing error code sc 538-01
    In the manual it says id sensor cleaning fan , i have replaced the fan with a working one from another machine, also i have troubleshot iob and all the power supply units thy are working, please help me out�� the error is persistant the machine does not even run on startup
    • 37532
    Re: Ricoh pro c5100 error code sc538-01
    It could also be the ITB Motor Cooling Fan. See the FAN DEFECT DETECTION portion of the service manual. Since the two are located next to each other check for clogged ducts or filters that could causing the fan to fail to come up to speed.
    • Chimatoner
      • May 2020
      • 4
      Solved, the error is caused by the drum face plate, its suppose to trigger a door switch, see attachement
      • bat
        • Sep 2008
        • 140
        Thank you for this, I've been struggling with this problem for a while.
        • M.wagih
          • Mar 2024
          • 19
          I have the same airbrush, but with a Ricoh Pro C7100 machine، Can you help?
          • bat
            • Sep 2008
            • 140
            problem
            I need more info about your problem...
              • 37532
              problem
              Maybe he should start his own thread instead of grave robbing one that is almost 5 years old/
              • M.wagih
                • Mar 2024
                • 19
                Ricoh pro c5200 how to fix error code sc689-00 Is it possible to help?
