Ricoh IS330DC Scanner - anyone have a customer still using this 11" x 17" SCSI model?
  • patterson70
    • May 2010
    • 599
    I have one of these but it has not been fired up in a few years and not sure if it will even work.
    And don't want to take up the time unless I can sell it.
    Requires a SCSI interface in the PC also. I am familiar with scanners and maybe this is still a good desk-top scanner that is heavy duty?
    Weighs a ton!
  • Notrons
    • Apr 2016
    • 71
    Re: Ricoh IS330DC Scanner - anyone have a customer still using this 11" x 17" SCSI mo
    Good luck finding a PC that has that interface, haven't seen one of those in years. Still, you might have some luck selling that thing on ebay. There are plenty of old PC buffs out there that might get a kick out of getting that old scanner to work.
    • sandmanmac
      • 3981
      X2 on that.
      Not to mention, I doubt that it would be compatible with an OS beyond Win XP
      • patterson70
        • May 2010
        • 599
        Thanks, and just FYI the SCSI interface can be added to any PC that has an open slot.
        • patterson70
          • May 2010
          • 599
          Originally posted by sandmanmac
          X2 on that.
          I checked and it does go to Windows 7 32 bit. That is for the Ricoh software.
          But wouldn't any scanner software work if you use it only as a TWAIN Scanner? (Dumb terminal)
          Such as Nuance Paperport, etc.?
          • sandmanmac
            • 3981
            I must admit, this is certainly not my area of expertise.
            It just seems like a lot of work, a limited need, and very little return for a 15+ year old unit - especially when you're not sure if it even works.
            • patterson70
              • May 2010
              • 599
              Thanks, yes this is why i asked if anyone still has a client using one. If so then maybe it is worth pursuing.
              They don't make these anymore, it is a desktop unit. That is it's only advantage.
              These days you would have to buy the entire floor-standing copier.
              Maybe some government agencies still use them.
                • 37488
                If it is the one I am thinking of, it is not a heavy duty scanner. It is basically the same ARDF used on a couple of copiers of the same vintage.
