Setting printer a0 ricoh 240w
  • mgipa
    • May 2020
    • 49
    Can you guide me how to install the Ricoh 240W A0 printer?
    • 37490
    Re: Setting printer a0 ricoh 240w
    It is covered in the service manual. RICOH AFICIO 240W SERVICE MANUAL Pdf Download | ManualsLib
    • Lewis-H
      • Oct 2020
      • 15
      1) If the problem is in an electrical circuit board, disconnect then connectthe board connectors again before you replace the PCB.
      2) If the problem is a motor lock, check the mechanical load before youreplace a motor or sensor.
      3) When a Level A or Level B SC occurs while the machine is in the SPmode, the SC number will not be shown. If this occurs, check the SCnumber after the machine goes out from the SP mode. This does notinclude Level B codes.
      4) Many SC codes contain more than one level (SC303-1, SC303-2,SC303-3, and others). Some SC codes can show a "-1", even if there isonly one level.
