c3002 re-use a (almost) new develoment unit
  • Mark Bbb
    • Jun 2012
    • 1662
    c3002 development unit initialization performed and only 10 printouts done.
    Can i re-use this development unit?
    The total cost for making a 3002 machine ready for sale here, are to high and perhaps we can re-use the dev.unit.
    Thanks - again - for your answer.
  • tjvincent
    • 280
    Re: c3002 re-use a (almost) new develoment unit
    Yes that's reusable, put it in another machine and tell it it's a new unit.
    • Mark Bbb
      • Jun 2012
      • 1662
      In the early day's you used the readings of the vsp & vsg and put those values in the other machine ...
      Is it still possible?
      Perhaps - as mentioned here before - just put it in, initialize it, and oeps, ready?
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Yes should be fine but setup as new
        Regards Mark
        • fshead
          • 2356
          I swap dev units and drums all the time as long as they arent worn out.
          Sometimes i will run a few test sheets and if not good black fill i will do a k forced toner feed and reprint test till it looks solid.
          And then i tell machine new unit both drum n dev unit and repower up..
          You can change just the developer powder too if needed
