Lanier LD127 (Aficio 2027) SC670
  • nb321
    • 8
    If machine goes to standby mode for few hours, on boot display SC670 code... (usually in the morning)... conections between board seems ok... any idea?
  • Jomama46
    • 2900
    Disconnect the HD temporarily to see if the problem goes away.
    sigpic
    A+; Network +; PDI+
    • Eric1968
      • 2458
      Could also be a defective network interface board.
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        Ditto the HDD
        • TonerMunkeh
          Professional Moron
          • 3865
          I think there's a firmware update for this, could be wrong like.
          Hit it.
          • Jimbo1
            • Mar 2008
            • 845
            It's a Ricoh. There's always a firmware update.
            "Some days you get the bear, some days the bear gets you."
            Cdr. William Riker
            • nb321
              • 8
              thanks, guys... but this is only copier machine, doesn't have HDD and network interface. I never didn't firmware upgrade that type of machine, (it wasn't necessery on another hundred machines of that type that i service) can you help me with that? new models have sd card reader, and it's not a problem, but this one need some IC card?
              that machine had simular problem few months ago, and then problem is desapire after few days, but right now it's constantly here...
              • Shadow1
                • Sep 2008
                • 1642
                Bad connection to the op panel - resolder the connector for the interface cable - had several with cold solder joints that would give this sort of problem
                73 DE W5SSJ
                • techspec
                  • Dec 2008
                  • 128
                  Remove the nvram and clean the legs with an emery cloth or scotchbrite, also a check of the SMC data might show up of few SC991 errors which go hand in hand with SC670
                  • tungnhung
                    • Dec 2008
                    • 26
                    No response from BCU at power on
