Sp9100dn
  • mdfurqan2012
    • 194
    Sp9100dn
    Dear all,
    I need support on Ricoh sp9100dn, when I want to print counter or configuration page machine start paper comes at registration and machine continuously runs for 1.5 minutes and after that machine exit blank paper and machine generates sc990.
    First when I reached that machine it generates sc865 which is HDD error, to format HDD I try to enter service but machine not enter in service mode so I replace HDD.
    HDD which installed in machine is 80gb and I replace it with 40gb after replacing of HDD machine easily enter in service mode and I format HDD successfully after that above sysmtom comes.
    I also swap complete drum unit from another machine but same symptoms on that unit.
    Kindly guide me.
    Thanks.
    Re: Sp9100dn
    Originally posted by mdfurqan2012
    Dear all,
    Kindly guide me.
    Thanks.
    YOU HAVE SEVERAL ISSUES HERE:
    1) what size / weight / orientation of paper should be 1st cassette LTR plain
    anything other than that you will get a jam code
    2) formatted HDD did you init it?
    did you load firmware for the machine?
    seems your knowledge of this machine would improve if you located a SERVICE MANUAL for the machine and then STUDY it.
    have you ever been trained on a Ricoh unit... any unit?
    • mdfurqan2012
      • 194
      Re: Sp9100dn
      A4 size 80gsm plain paper is used in 1st tray
      No machine generates sc990. No jam code
      Yes
      No
      I read service manual and there is no information for sc990.
      Yes I have training of
      Mp1350
      Mpc5000
      Sp8200
      I replied your queries
      • mikadonovan
        • May 2008
        • 2931
        Re: Sp9100dn
        This may be an issue. I have replaced HDD's with a slightly larger one with no issues, but not the other way around. The machine may require at least a 80gb HDD volume to function correctly. Just a thought.
        NEVER ASSUME ANYTHING
        • TonerMunkeh
          Professional Moron
          • 3865
          Re: Sp9100dn
          Agreed, you can only go up in capacity, not down.
          Hit it.
          • mdfurqan2012
            • 194
            Re: Sp9100dn
            Today I change hdd with 80gb but issue not resolved even though I also check bicu board and ipu board from a ready machine and also complete drum unit from that machy but issue not resolved.
              • 37556
              Re: Sp9100dn
              Which issue, the SC 865 or the SC 990?
              SC 990 is a software error.
              Reflash al firmware.
              Replace RAM DIMM modules
              Replace NVRam
              Replace BICU/Controller
              Check your AC line condition. Surges, sags, spikes and RF noise can blow electronic components. If you do not have a quality line conditioner installed, install one. If you do have one and it is more than 2 years old, replace it. They are a lot less expensive than frequently replacing boards.
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Re: Sp9100dn
                Was the HDD and bicu etc from same model
                Regards Mark
                • mdfurqan2012
                  • 194
                  Re: Sp9100dn
                  Both are from Same model and working condition machine
