i have install new fusing belt for mp c8002 and it tears with worming up the machine,i didn't even print to test it,i checked the installation all is fine,also i've replaced the hot roller and same occurred,any suggestions please?
mp c8002 fusing belt tears
Re: mp c8002 fusing belt tears
Did you also replace the rest of the rollers in the fuser? If you're in there you may as well.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it. -
What are the Part Numbers for the Belt and Hot Roller you replaced?
There's a bulletin about the "Heat Roller Assembly" where the flanges slip inside the metal sleeve and those swell up and touch the belt causing it to be torn.
New roller Part Number is D1364450, i would check and Replace this roller.OmertÃComment
Regards Mark
https://copierservices.simdif.comComment
Hit it.Comment
Also...there are two shoulder screws either side of the fuser that hold the belt unit in.
If you mistakenly use NON shouldered screws when you rebuild it...you'll shred the belt eventually.
It puts too much pressure on the frame and runs the belt off to one side.
Found that out the hard wayComment
would you please point where they are located exactly? or could you point on them on service manual please?
thanksComment
I followed the new modification
heat roller D2584460
bushing :heat roller:shaft D2584467
flat belt-fusing DIA75 D1364181Comment
