Printer problem
  • kanagavel
    Service Engineer
    • Feb 2020
    • 78
    [Misc] Printer problem
    Hi friends MP5000 after updating firmware the printer option not available i don't know what problem but scanner option showing and working normally then i try again firmware update but there is no option for update printer firmware but the same firmware card i use other machines its showing all updates i don't know how to solve this problem please help me friends...
    Thank you.
  • Brianneoe
    • May 2015
    • 318
    Re: Printer problem
    The Gooses Guide shows only one entry to your issue.
    PRINT OPTION NOT RECOGNIZED No print option - has B model board installed in machine
    Did you replaced a board?
      • 37490
      Re: Printer problem
      Are there any recent HDD related SCs? The print function requires the HDD. You also may have had a failure of the Printer/Scanner SD card in slot 1. If the machine is an original SP model the service spare part number might be printed on it.
        Re: Printer problem
        There is a service mode setting that turns off the print and usb but I cannot remember what it is.
        Has the op been playing with the nvram?
          • 37490
          Re: Printer problem
          SP 5985-001 for the NIC and SP 5985-002 for the USB just turn off the ports. Printer function will still show in User Tools, Printer Sp will still show in SP mode and Printer firmware will still show in firmware update.
          • Brianneoe
            • May 2015
            • 318
            Re: Printer problem
            There are 2 different versions of that machine,SP and B. Are you sure your using the correct firmware. The B version won't give you the option to scan in color.
            If no boards were replaced and you reseated the 256MB DIMM on the controller then check if the machine has a fax board. If it does, disconnect it and reboot. As Slim stated check out the HD. SP mode 5832 will allow you to reformat the drive. Web into the machine first and back up the address book before you reformat the HD. SP mode 5801-008 will clear the printer module. Never do a all clear (5801-001 or 5801-002) unless you have the machines birth certificate. I don't know your history with this unit i.e. did you just picked it up as a customer or have you been working on it for a long time. More info will be needed to nail this down if you have not done so already.
            • kanagavel
              Service Engineer
              • Feb 2020
              • 78
              Re: Printer problem
              Hi sir thank you for the reply, sir actually my problem is i prepared one MP5000 machine after that i saw the firmware version is old so we have new version in my office so I try to update firmware after update is see there is no printer option and i see in sp mode there is no printer sp then again i try to update firmware by using same card but there no option showing for Printer firmware update then i try the same card to another machine its working fine. I try HDD format and i replace the HDD, i try sp5801 i did all clear no use then i try NV RAM flashing still change. Then i try with another machine controller boad it is ok but still i don't know how to solve this problem
              • kanagavel
                Service Engineer
                • Feb 2020
                • 78
                Re: Printer problem
                Hi sir thank you for the reply, sir actually my problem is i prepared one MP5000 machine after that i saw the firmware version is old so we have new version in my office so I try to update firmware after update is see there is no printer option and i see in sp mode there is no printer sp then again i try to update firmware by using same card but there no option showing for Printer firmware update then i try the same card to another machine its working fine. I try HDD format and i replace the HDD, i try sp5801 i did all clear no use then i try NV RAM flashing still change. Then i try with another machine controller boad it is ok but still i don't know how to solve this problem. And after this problem comes machine always showing SD card authentication failed.
                • davel
                  • Oct 2011
                  • 1104
                  Re: Printer problem
                  Sounds like it might be a MP5000B but you have killed it by doing 5-801 all clear.
                    • 37490
                    Re: Printer problem
                    The Printer/Scanner SD Card has failed. Nothing you do will correct the problem until you replace the SD Card.
                    • FrohnB
                      • Jul 2017
                      • 1919
                      Re: Printer problem
                      Did you remove the Printer/ Scanner SD card when you did the update, and then just forgot to put it back in when you were done?
                      Printer Scanner Unit Type 5000 (SD card) - Part Number 414380.
                      Omertà
                      • mikadonovan
                        • May 2008
                        • 2931
                        Re: Printer problem
                        Originally posted by promotion.mansher
                        Thank me after its done![emoji4]
                        The ONLY thing we will thank you for is to move on and take your spam off this tech site.
                        NEVER ASSUME ANYTHING
                          • 37490
                          Re: Printer problem
                          6 posts. All today. All illegal advertisements. All reported.
                          • M94
                            • Jul 2020
                            • 158
                            Re: Printer problem
                            Yup I'm doing that now.
                            RIP adboi reputation
