MPC 2800 showing restart when power on in the morning, before showing ready
  • alvin_3000e
    • Dec 2008
    • 31
    Hi,
    Got some issues with mpc 2800 copier going into restart state most of the time in the morning when switching
    on power supply. After restart, then it goes ready.
    I have formatted the hardisk of the copier and it is still the same.
    Any other problems with the mpc 2800 causing this issues,
    Thanks,
    alvin
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: MPC 2800 showing restart when power on in the morning, before showing ready
    Originally posted by alvin_3000e
    Hi,
    Thanks,
    alvin
    What does SP5-990-004 logging data say as far as SC codes go?
    • mrwho
      Major Asshole!
      • 4299
      Hi,
      Thanks,
      alvin
      If it shows the restart screen, it means it must have logged an error code - you need to check the logging data (or print one with sp5990-04) to know what error is there before trying to fix the problem.
      Mascan42
      Ibid
        • 37652
        Change SP 5875-001 SC Auto Reboot from 0(default) to 1. In the future the machine will show the SC code instead of the Restart message.
