Ricoh Aficio 2015 and Scanner Problem
  • cixio79
    • Aug 2025
    Hi,
    I'm having some trouble with my copier/scanner.
    It works as copier and printer but doesn't as scanner.
    When I try to import anything from the scanner by using the TWAIN driver, I get an error message:
    Error 12320 Unable to locate scanner. Make sure scanner is connected and power is on
    Everything worked fine till some day ago...and I didn't change anything before to get that message, so I don't understand what's the problem.
    I've already tried to disable Windows Firewall, to re-install the Twain Driver... with no success .
    Can anyone help me, please?
    Cheers from Italy
  • claudioterrible
    no mercy...
    • Oct 2008
    • 96
    scanner problem
    how the machine is conected?
    • cixio79
      Sorry, I thought it wasn't important 'cause the machine is connected as always...
      Anyway, it's connected through a router then a hub-switch. I tried to restart both (router&hub), but nothing changes!
      I also checked the Web Image Monitor and it says "Scanner Ready"
      • schooltech
        School District Tech
        • Jun 2008
        • 504
        My initial guess on this would be something software related. I would try to go back to when it worked, see what was installed/uninstalled/updated since then and try to troubleshoot.
        Of course, it could be machine related, but usually when things worked fine, then suddenly stop working, I go the software route and do some quick checks.
        Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
        • cixio79
          Please, let me know your success
          I forgot to add: of course, every PC linked to the scanner receives the same error!!
          • Jomama46
            • 2900
            Try turning off your firewall and see if it works
            Try turning off your Nortons/Symantic/anyother software guard sys and see if it works.
            sigpic
            A+; Network +; PDI+
            • cobiray
              Passing Duplication Xpert
              • Mar 2008
              • 1199
              I hate to be that guy, but did you cycle the main power on the machine?
              • Jomama46
                • 2900
                Somebody had to say it
                sigpic
                A+; Network +; PDI+
                • schooltech
                  • Jun 2008
                  • 504
                  My success? Why, did you want me to go fix it for you?
                  You'll figure it out, you just need to think, from the scanner portion, and narrow it down. Power cycle it, go into the scanner portion, make sure the machine is properly recognizing its own scanner option.
                  Forgetting to add that now makes me think that it might be a machine software glitch, rather than a computer software issue.
                  • cixio79
                    Ok guys, thanks for your advises.
                    At last, after I tried everything, I turned off the main power line of my office, just to be sure to turn off every machine/router/switch/ecc at the same time and rebooting it at the same time too.
                    Well... NOW IT WORKS!
                    I turned off the stuff once a time... that was my fault!
                    @Cobiray: I hate you too, don't worry! Eheh, just kidding
                    @Schooltech: I'm sorry but I've fixed it before of you! What I won?
                    • schooltech
                      • Jun 2008
                      • 504
                      What you win is support from this forum when you need it. There are lot of good people on here that are willing to help.
                      Good luck in the future.
