MPC307 leading edge
  • GeorgeBest
    • Jul 2009
    • 525
    MPC307 leading edge
    HI
    When copying or printing more then one prints, the registration is not correct.
    Sometimes it is 1 or 2 inches below the head . . .
    Does this mean that the registration clutch need to be changed?
    only 5K on the counter . . .?
    Thanks in advance
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MPC307 leading edge
    That is usually caused by the side door, the hooks that latch onto the transfer unit have a shaft that runs through the middle of them twists and the door doesn't latch correctly.
    Hit it.
    • GeorgeBest
      • Jul 2009
      • 525
      You're sure about that, because the side door closes correct . . .
        Originally posted by GeorgeBest
        HI
        Thanks in advance
        George,
        is there an error code?
        do the paper types/sizes/weights match on PC & copier/printer settings?
        what have you done?
        cleaned sensors?
        feeds?
        registration assmy?
        are all bushings/springs/clips in place?
        paper guides tight against media?
        so many questions... so little info.
        Phil B. "The Dentist"
        • GeorgeBest
          • Jul 2009
          • 525
          Hi Phil,
          no error code,
          paper sizes are correct, first copy and print always good, more then one it gives an registration fault without an error, not always . .
          Cleaned pickup and registration roller, and checked the ITB unit
          paper guides allright, just one cassette
          bushes seems to be in place, again first copy/print always good.
          registration clutch not in store, think its the clutch, but with 5K on the counter?
          George,
          what have you done?
          cleaned sensors?
          feeds?
          registration assmy?
            Hi Phil,
            no error code,
            ok then next thing i would check is that all wire harnesses are pulled reconnected (with pwr off)
            clean the feeds/make sure they ae locked in place.
            • Hacke_73
              • Feb 2020
              • 1
              Did u solve the problem?
              • GeorgeBest
                • Jul 2009
                • 525
                yep, it was the clutch ....
