MPC307 registration ?
  • GeorgeBest
    • Jul 2009
    • 505
    Hi,
    Still got this problem on an MPC307, with only 6K Black on the counter.
    see the example . . . First, second and third output, registration leading edge..
    Did the firmware, checked fuser, ITB and registration roller.
    To do an registration clutch replacement, its quite a job, can't image this on a 6K count
    anyone another idea or clue before I go for the clutch . . .
  • davel
    • Oct 2011
    • 1045
    Re: MPC307 registration ?
    Rego roller is not stopping at the right time, try sensor first then maybe clutch bad and staying on.
    • aktasson
      • Feb 2017
      • 201
      Originally posted by GeorgeBest
      Hi,
      Thanks in advance
      I had a similar problem on a A3 mpc, but same on feed direction. In my case it was the drive/motor to development unit. First page mostly was good, but the next pages on a multiple print/copy job shifted.
      CHeck in sp (test pattern) with copy mode if this happen same for each pcdu color unit.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Hi,
        Thanks in advance[ATTACH=CONFIG]46070[/ATTACH]
        Looks like Registration clutch problem not to hard to replace
        Regards Mark
        • black
          • Aug 2015
          • 6
          Fixed it replacing regist. clutch.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Well done good job thank you for letting us know.
            Regards Mark
