P800 SP MODE CODE??
  • Johnysg11988
    • Feb 2019
    • 14
    [Misc] P800 SP MODE CODE??
    Ricoh P800 sp mode code??
    Any suggestions??
    Re: P800 SP MODE CODE??
    Any suggestions??
    what do you want?
    the entry code to SP mode?
    • FrohnB
      • Jul 2017
      • 1919
      Same as all the other machines that have the G2 and G2.5 Smart OP's.
      Omertà
      • Johnysg11988
        • Feb 2019
        • 14
        P800 has not G2 smart OP's
        • Johnysg11988
          • Feb 2019
          • 14
          what do you want?
          Yes my friend..i dont know it for this machine
          • FrohnB
            • Jul 2017
            • 1919
            You're right, it doesn't have the G2, it has the G2.5 Smart Op panel, which has the same access procedure as the G2 Smart op panels.
            Ricoh machines have used the same 6 digit access code since the Cxx03 Models (7 years now).
            Omertà
            • Johnysg11988
              • Feb 2019
              • 14
              I know access code..but this model has not G2 or G2.5 Op panels..
              P 800 | Single Function Printer | Ricoh | Ricoh Europe
                • 37345
                Try holding down the Up and Down scroll buttons for 5 or more seconds then press the OK button.
                • FrohnB
                  • Jul 2017
                  • 1919
                  Oh shit, Sorry about that, i was thinking the MFP version for some reason.
                  Slimslob may be right. hold down the up and down arrows for 5 seconds then release and hit the ok button.
                  Omertà
                  • skinnyb
                    • Jul 2008
                    • 291
                    Bingo. P800 is a printer only. Worked on one today. It's the printer version of the IM550. Very wierd unit, Kyocera hardware with a Ricoh controller... Definitely not what I'm used to...
                    Sent from my LM-V405 using Tapatalk
                    • davel
                      • Oct 2011
                      • 1094
                      P800 is one of those Kyocera rebadged POS.
