306z smbv2 and v3
  • ABS tect
    • Sep 2013
    • 511
    306z smbv2 and v3
    why is it not holding when i select smbv2/smbv3 to be "active" and port number "445" under system settings, interface settings, smb client advanced settings.
    It won't hold...tried going in as admin and still nothing. So i can't scan without enabling smb 1.0 which i don't do
  • aktasson
    • Feb 2017
    • 201
    Re: 306z smbv2 and v3
    • SP5-728-040: Port number default 445(0), 139(1) --> 445=1
    • SP5-728-041: default SMBv2/SMBv3 Active(0), Inactive(1) --> Active=1 ...
    • Minimum FW Package D1965406Tv Ver.15.00
    • Minimum reqired FW
      Model
      D219/D220/D214/D196/D236
      v1.15
      D1965400S
      v15.27.1**
      D1965792J
      v15.28 ***
      D1965792K
      v01.19
      D1965787L
      v1.12
      D1965788K
      Animation
      v2.06
      D1965790G
      already checked?
    • ABS tect
      • Sep 2013
      • 511
        Model
        v1.15
        D1965400S
        v15.27.1**
        D1965792J
        v15.28 ***
        D1965792K
        v01.19
        D1965787L
        v1.12
        D1965788K
        Animation
        v2.06
        D1965790G
        already checked?
      Thanks man...i believe my individual modules were not up to date but once i updated with package firmware all is well...
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        I find it's better to update all individual firmware as some modules are more up to date than package
        Regards Mark
          • 37474
          I have also found that if your MFP has a problem caused by a corrupted firmware module Package will not replace it as long as it is current.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            The package firmware has always given more problems ricoh are always posting on technical not to install quite a lot
            Regards Mark
            • ABS tect
              • Sep 2013
              • 511
              Yea i've found this issue interesting. I've always been the one to install the individual modules. However, if you've seen some of my recent threads, i've fixed the last two issues by loading the package firmware. One on this machine, and one on a MP C3503z.
              That doesn't mean that package is the way to go...it could simply mean my individual ones were not all up to date (more than likely).
                • 37474
                Package firmware is the fastest(???) way to update a machine that has multiple firmware that are out of date.
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Fastest but not the most up-to-date
                  Regards Mark
