MP C2503 and MP C3004
  • Hoosierdaddy
    • Oct 2016
    • 181
    Both of these machines give a Quick Service Code 06-06 or 06-01 when faxing. Does anyone have any experience with this type of issue? They have a Citrix switch in there telephone system. I dont know where to go with this. I have adjusted the baud rate in Fax Service Mode Tech Support
    Thx for any he
  • aktasson
    • Feb 2017
    • 201
    Re: MP C2503 and MP C3004
    I have a lot settings for foip (voip) terminal adapter environment. But in many cases i just configured the baudrate to 9600 and ecm for sending and receiving to off. This was enough. Newest adapter don't handle with pbx setting of the machine (wondering, because no hook up or tel switch tones hearable) , so i set the line to pstn and it works in most of my cases.
      • 37442
      Print the fax error log. Result code numbers are listed on the page.
      • Hoosierdaddy
        • Oct 2016
        • 181
        The customer is using a PRI . The call leaves the PRI and completes on the handshake on the other end but then the call drops off. Is the PSTN setting in the same area as the Baud rate ?
