RICOH AFICIO MP C3001 Image problem
  • andrec123
    • Nov 2015
    • 9
    [Misc] RICOH AFICIO MP C3001 Image problem
    I have a problem with the RICOH AFICIO C3001, in normal A4, the prints are from the middle down with this effect as I leave attached, I already cleaned the mirrors of the laser and it remains the same do I have to change the laser unit?
    Re: RICOH AFICIO MP C3001 Image problem
    What are the page counts on drums/dev's?
    Are you using genuine oem ricoh toners?
    Have you run the SM reports?
    what are bias levels?
    So many questions so few answers.
    Phil B. " The Dentist "
    • mikadonovan
      • May 2008
      • 2931
      Before you do that, since it is affecting ALL colors, could be an ITB issue, or paper transfer roller problem.
      NEVER ASSUME ANYTHING
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Is this done in a4 or a4r
        If a4 {portrait} look at the ptr assy
        Regards Mark
        • FrohnB
          • Jul 2017
          • 1919
          +1 on PTR!
          The case that PTR roller sits in on the right-hand door has a plastic post/ pin that breaks off on the rear side. You can check that by grabbing the PTR and see if the Rear side lifts up.
          If it's not that, then Sometimes it is also the docking bracket on the ITB that the PTR sits in when the door is closed. It can be broken, and makes it so that the PTR is not sitting correctly against ITB.
          These are what i would check First.
          Omertà
          • andrec123
            • Nov 2015
            • 9
            Yes the toners are original, I checked it all and they are in the normal parameters.
            I have already checked the ITB and I do not see any anomalies.
            In A4, in A4R it does less.
            Originally posted by FrohnB
            +1 on PTR!
            I already changed the PTR unit once, it has about 10,000 copies, I was watching it and I didn't check for any anomalies but I can check it again when I go to the customer.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              It's very unlikely its laser as all colours it will be ptr alignment to transfer unit check where the ptr roller sits to the transfer unit it will be in that area the problem
              Regards Mark
                • 37533
                To be clearer, is it long edge feed or short edge feed? Portrait and landscape refer to how you hang a picture on a wall.
                • frere
                  • Jun 2020
                  • 12
                  First you need to know where you are loosing the density. Make a copy or a print and open the door while it's running .have a look on the ITB if you have the same pb; IF the image is ok on the ITB then make a copy (or print) on A3.It should be better, like you said it's better on A4r that's because the A3 and the A4
                  are hold at the same time by the Fusion unit and registration roller that makes the paper to be straight and in contact very close with the ITB.
                  Like every body said it's about the PTR. Have a look if the roller is not lower in his casing rear than front.On that machine it's the ITB unit who pushes the toner
                  on the paper, the current on transfert roller is not important but the physical position of the PTR is.
                  Good luck
                  • andrec123
                    • Nov 2015
                    • 9
                    Thank you! I will test on the client and then I will give you news!
                    • andrec123
                      • Nov 2015
                      • 9
                      it's already solved! It was the PTR out of place thanks a lot!
                      • mga
                        Copier Technician
                        • Dec 2010
                        • 1393
                        Sorted well done and thank you for letting us know the outcome
                        Regards Mark
