Ricoh mp301 will not print from computer
  • anica
    • Dec 2014
    • 12
    a Tech remove the mp301 from a network connection. He left it next to the new one. I connect it to a computer, install mp301 pcl6 driver, and it will not print. When you ask the printer for it's settings it does print it. I then connect the printer via a router, the computer can ping the printer, the printer can ping the computer, but refuse to print. I am wondering if I have the wrong driver. Help will be appreciated.
    • 30294
    Re: Ricoh mp301 will not print from computer
    Download and install the correct driver from Ricoh
    Set it up to print from the ipaddress raw 9100 port
    • anica
      • Dec 2014
      • 12
      Is there a way to do it via the usb cable. [direct printing], this is the prefer way.
      As mention, it does not work currently.
      • Brianneoe
        • May 2015
        • 322
        Set the machine to auto obtain under IPv4 settings. Do you get a valid IP address? Also check IPsec. If its on turn it off. Can you web into the machine and check your port settings. Yes you can connect using a USB but you won't be able to scan.
        Can you print using your laptop?
        If you search this Ricoh tread for Wont Print, you will see a lot more info.
        • 8T2
          • Aug 2015
          • 257
          Does the print job fail and stay in print queue om PC or is the print queue empty? If it's empty you're probably missing a user code, if it's still in queue it's probably trying to send it to the wrong IP address
          Sent from my WAS-LX1 using Tapatalk
          • copyaction
            • Oct 2007
            • 991
            Check sp 5985 that USB is set to on.
              • 37532
              Check SP 5985-001. It should be set to 1.
              Did you check to see if IEEE 802.11 is enabled in User Tools? If it is disable it.
              • anica
                • Dec 2014
                • 12
                it stay in print queue on pc, not on printer
                • anica
                  • Dec 2014
                  • 12
                  I will check as soon as I have time, thank you.
                    ok since it prints it's settings please upload to CTN in PDF format.
                    like someone mentioned you WILL NOT be able to scan to email etc via USB..
                    since you can ping in and out .. it would seem to be a simple setting, once you upload your pages we can help you even more.
                    also include the error log sheet
                    • 8T2
                      • Aug 2015
                      • 257
                      I'm guessing the wrong port is selected on the driver. Your original post is a bit confusing are you trying to print via USB or IP? If you're trying to print via IP make sure the old machine and new machines aren't using the same IP address because I generally recycle the old IP when replacing a device.
                      • sandmanmac
                        • 3981
                        I'm confused by your post.
                        Was the machine working before and it has stopped, or is it used machine that you acquired or that you're reselling, that was not tested previously?
                        Sounds like it may have an access range set from previous owner. Check the bottom of the configuration page under "interface information"
                        If so, you'll have to telnet in and flush it
                          • 37532
                          I don't know on these entry level models but on the larger model you can clear it with SP 5801-011 NCS Network Control System.
                          • sandmanmac
                            • 3981
                            With all due respect, Tim, that SP mode does not clear or reset the access range, it basically only resets the host interface settings to default.
                            The only way I've ever been able to clear access range on ANY Ricoh device is via Telnet - including just now, when I re-confirmed it for myself on my own MP305+ so as to not put my foot in my mouth
                            • CopyBats
                              • Aug 2011
                              • 147
                              Either Telnet, or you have to assign a computer/laptop an IP address within the range and then connect with the machine on WIM and remove the access range.
                              I wish NCS clear got rid of the range , but it doesn't.
                              If it works, don't touch it.
