ITB Stopper MPC3002
  • skynetto
    • Sep 2012
    • 257
    ITB Stopper MPC3002
    Hi guys.
    Can someone confirm me if the right ITB stopper of MPC2800 code: B2236085 can fit in the MPC3002 ITB?
    I dont have any 3002 in hand to check myself, and the one i'm going to service have the stopper broken.
    Thank you.
  • 8T2
    • Aug 2015
    • 257
    Re: ITB Stopper MPC3002
    I think that stopper is basically interchangeable on all the ITB's that look like that from when the MPC2000 came out till the 3002 came out. So loads of models you can steal one off
    Sent from my WAS-LX1 using Tapatalk
    • skynetto
      • Sep 2012
      • 257
      Thnx man. Will try it today and send feedback.
        • 37628
        For some reason Ricoh in all their wisdom decided to only make the entire ITB unit available on the 02s. The part number for that part on 01s is the same as on the C2800. The part number for the 03s is D1496037.
        • skynetto
          • Sep 2012
          • 257
          OK. Confirmed guys. The stopper works there too.
          The initial problem was SC460 followed by SC492. Seems the if the ITB is not firmly in place you get strange high voltage errors.
          • Imprestik
            • Aug 2012
            • 297
            why not just use the maintenance kit transfer units for the 3002 PN: 407037
            So much cheaper than rebuilding and comes complete with the cleaning unit
            • skynetto
              • Sep 2012
              • 257
              It has only the stopper broken. Some 'tech guy' must have used hulk force to brake it.
              The belt is ok anyway.
                • 37628
                On the Cxx03 a broken ITB stopper will allow the PTR end of the ITB assembly to move slightly when the shutter solenoid for the ID sensor assembly energizes. Just enough to cause the sensors to not be fully uncovered.
                • fshead
                  • 2378
                  i would find cheap SPC830 ITB units and just swap the upper guides..
                  i think mpc2800/c3300/c3001/c3002 ITB units are all the same
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Not sure if the mpc3002 is the same as I think the ptr roller and top case is a different size but you may be correct.
                    Regards Mark
                    • fshead
                      • 2378
                      true PTR are different diameter but the ITB unit is universal as is the belt alone..
                      minor tweaks,a tab here or plastic cover..
                      I recycle a lot of parts and its helps in the end..............
                      • Notrons
                        • Apr 2016
                        • 71
                        Can you just remove the shutter?
                          • 37628
                          You can but it also acts as a dust shield for the ID sensors. You would be having to clean the ID sensor assembly a lot more frequently.
